cagatayantmen's avatar
Jul 05, 2023
GS110MX UpTime ?
Hi,
Whats the uptime (ms) when GS110MX power cut off ?
Thanks.
  • michaelkenward's avatar
    michaelkenward
    What do you mean by "uptime"?
    The GS110MX is an unmanaged switch.
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Switches - NETGEAR Communities
    You might like to search there for messages related to your problem.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • The uptime (ms) when the power is cut off for a GS110MX switch cannot be accurately determined as it varies based on several factors such as the specific configuration, load on the switch, and other environmental conditions. Additionally, the GS110MX switch is not designed to provide an uninterrupted power supply (UPS) functionality, which would allow it to continue operating during a power outage. When the power supply is abruptly interrupted, the switch will lose power and immediately shut down. The switch will remain offline until power is restored and it is manually powered on again. The duration of the power outage and the time it takes to restore power will determine the total downtime of the switch.
ProSupport for Business
