GSomma
Dec 18, 2023Initiate
GS305/8E. Unable to save VLAN config.
I have GS305E and GS308E switches (Firmware 1.0.0.11) that I configured with VLANs. If I try to make a change, when I access "VLAN - 802.1Q - Advanced - VLAN Configuration" I find "Disabled" and if ...
- Dec 18, 2023
These switches come confusingly with different VLAN configs and settings.There are other VLAN config variants, different from the "VLAN - 802.1Q - Advanced - VLAN Configuration". When changing to this mode, the previously existing dot1Q (when I remember right probably all VLAN configs as rh UI says) must be redone. Suspect you had some basic 802.1q config or the plain port based VLAN settings in place before.
schumaku
Dec 18, 2023Guru - Experienced User
GSomma
I understand, I need to select VLAN - 802.1Q - Advanced - VLAN Configuration.
This is how I see the previous configuration.
Thank you. I was "lost" in the menu.
