dmac001
Jan 16, 2024Tutor
GS308EPP 8023.af support 24v passive Ubiquiti AP
Hi, can anyone tell me if the GS308EPP will support a 24 volt passive Ubiquiti AP with 8023.af? All the documentation talks about power consumption, watts,... but not volts. I'm assuming the GS308E...
dmac001
Jan 16, 2024Tutor
I agree, the Ubiquiti APs with non-standard 24v/48v passive POE unnecessarily confuses the space.
My "newer" AP-Lite (build 33) supports 802.3af (and as labeled on the bottom) so it should work with the GS308EPP; however, it also runs with 24v passive POE which I thought would be a problem with 48v 802.3af POE.
I should have the replacement switch tomorrow, so I'll be able to confirm. Thanks again for all the comments!
Don
dmac001
Jan 18, 2024Tutor
Just to close out this discussion, my Ubiquiti AP 802.3af works fine with the Netgear GS308EPP. Thanks for everyone's comments.
