Domer99
Jul 18, 2023Initiate
GS324TP Firmware update not working
Hi all, I'm trying to update the firmware on my GS324TP. It's currently at firmware 1.0.0.26 and wanting to update it to the latest version which is 1.0.0.43. Followed the instructions, used the we...
- Jul 18, 2023
Head to the S350 Series 24-Port (PoE+) and 48-Port Gigabit Ethernet Smart Switches with 2 or 4 SFP Ports User Manual p.331, Manage Software Images.
now head to Maintenance > File Management > Dual Image > Dual Image Status
Dual Image Status information - Field Description
Image1 Ver The version of the image1 file.
Image2 Ver The version of the image2 file.
Current-active The currently active image on this switch.
Next-active The image to be used after the switch reboots.
Image1 Description The description associated with the image1 file.
Image2 Description The description associated with the image2 file.Which version is shown for the image1 file? The one you uploaded before?
On Maintenance > File Management > Dual Image Configuration you can define which image will be come active after a restart.
The magic of switches with dual flash images. Worth reading the fine documentation.
schumaku
Jul 18, 2023Guru - Experienced User
Domer99
Jul 19, 2023Initiate
This was super helpful. Was exactly what I needed. I had read somewhere that image 1 was the default boot image so thought I should have been set when uploading the new firmware to image 1. I did have some earlier issues uploading the file though and think I might have switched the image to image 2 during that process. Forgot to go change it back. Thx!
