Andreas_B
Feb 25, 2022Guide
GS716v2 VLAN with LAG
Hi I'm a little bit confused about a HowTo :-/ I've two GS716v3: Both are connected via LAG1 (via SFP) Switch #1 has VLAN6 has the Memberports 9 (U), 10 (T), 11 (T), 12 (T) Switch #2 has VLA...
- Feb 26, 2022
Andreas_B
Feb 26, 2022Guide
Hi@All
Here are now my configuration and painted solution of my Issue.
Please remeber that before you create LAGs, disconnect physical the needed ports from LAN.
Otherwise you will possible run into a packet storm and you are unable to configure your settings ;-)
Thanks @ All
