PhilJW
Oct 09, 2014Aspirant
GS724T affecting internet upload speed??
Can anyone help with this please.
I have BT Infinity 2 with a Home Hub 5 router/modem.
I am getting excellent download speeds (70+ Mbps) but dreadful upload speeds (2 Mbps) when my PC is connected to my home network ie through my GS724T switch.
However if I connect my PC directly to the router all is well (speeds of 15 Mbps). And I get the same speeds if I connect wirelessly.
So BT (probably quite rightly) say its an issue with the switch or the cables.
I cannot see how its the cables as surely if they were faulty it would affect download speeds as well.
If so I am assuming that its a configuration on the switch I have not set correctly.
Can anyone suggest what I need to do? And I am not hugely technical so some hand holding would be appreciated.
Many thanks
1 Reply
- aditMentorCheck the firmware on it. Factory default it if necessary. Replace the cable between the router and the switch.
