GDJ777
Dec 12, 2022Follower
GS724T Switch Hardware Version ID
I have a very similar problem to other posts ... inherited a Netgear GS724T smart switch but do not know the model version number and how to upgrade firmware. Below is a summary of the relevant switc...
Marc_V
Dec 12, 2022NETGEAR Employee Retired
@GDJ7777
Welcome to the Community!
Can you locate the label on the switch? From the version currently installed it might be a possible V1 or V2. It Usually says the version on the label GS724T-200***
Regarding update, the version is not showing as available but once we have determined the version of the switch it would be best to continue upgrading the switch in a ladderized manner.
HTH
