GDJ777
Dec 12, 2022Follower
GS724T Switch Hardware Version ID
I have a very similar problem to other posts ... inherited a Netgear GS724T smart switch but do not know the model version number and how to upgrade firmware. Below is a summary of the relevant switc...
schumaku
Dec 12, 2022Guru - Experienced User
We're facing some almost two decades old GS724Tv1 or v2 hardware platform.
-> https://www.netgear.com/support/product/GS724Tv1.aspx#download
-> https://www.netgear.com/support/product/GS724Tv2.aspx#download
Either way the Smart Wizard Utility https://www.netgear.com/support/product/Smart%20Wizard%20Utility.aspx is required.
For detailed insight, consult the "View Previous Versions" and the "View Current Version" - there are docs or readmes included.
For detailed actions or processes, please feel free to ask . I'll try to find some Netgear friends with insight.
Scratch the idea having same versions in sync - we it's about features/functionality and and probelm fixes.
