funhouse69
Jan 13, 2012Aspirant
GS724TP VLAN Issues
I just added a GS724TP to my network, it is showing the latest firmware 5.0.0.15 with the Boot Version of 1.0.0.5. This switch was added to utilize the POE feature of the new GS108T (New Gray ones). ...
marcoreedijk
Oct 07, 2014Aspirant
Our solution:
Change the PVID of the desired port to the other VLAN.
Then the port will be automatically removed from VLAN 1
You can do this by checking the row in PVID Config and fill in the right VLAN ID in the textbox above the list and click APPLY
