Marsky
May 03, 2016Follower
GS728TPSB - Change SFP Stacking mode to optical uplink mode
Hello, I have a Netgear Switch type GS728TPSB and I cannot use the SFP Port 27 and 28 to connect a typical network videoencoder. Ports 23 - 26 are working with this encoder, but Port 27 and 28 n...
mgmtmt
May 09, 2016Tutor
I believe the setting is under System > Stacking > Advanced > Stack Port Configuration, and you'll have to check on one of the stacking ports and change its Configured Stack Mode to Ethernet.
