Nordman49
Nov 06, 2017Aspirant
GS908E switch problem : orange led and impossible to reach admin page
Hi everybody, I've got problems with my brand new GS908E administrable switch : - the front led is orange instead of blue - it's impossible to access to the management page However, the Netgear S...
- Nov 16, 2017
Problem solved : a simple reset was sufficient !
Thanks to the very effective and pleasant Netgear support
JohnC_V
Nov 07, 2017NETGEAR Employee Retired
Hi Nordman49,
Welcome to our community!
As per checking in here that you just purchased a brand new GS908E. May I know if you do have a router on your network where the switch is connected? By the way, it has a 90-day complimentary technical support so you may take advantage of that. You may open a chat / case online on NETGEAR support.
XavierLL
Nov 08, 2017NETGEAR Employee Retired
Hi Norman49,
I will also suggest that you check that your Computer is in the same network as your GS908E, that´s normally one of ther reaons why you can´t access the network interface. Could you try to ping the switch ?
Moreover normally the GS908E LED turn it amber when it detects some issues on the network, so could you also try with another cable to make sure that´s not a physical issue.
Xavier Lleixa
NETGEAR CBU PLM
- Nordman49Nov 16, 2017Aspirant
