Nordman49
Nov 06, 2017Aspirant
GS908E switch problem : orange led and impossible to reach admin page
Hi everybody, I've got problems with my brand new GS908E administrable switch : - the front led is orange instead of blue - it's impossible to access to the management page However, the Netgear S...
- Nov 16, 2017
Problem solved : a simple reset was sufficient !
Thanks to the very effective and pleasant Netgear support
XavierLL
Nov 08, 2017NETGEAR Employee Retired
Hi Norman49,
I will also suggest that you check that your Computer is in the same network as your GS908E, that´s normally one of ther reaons why you can´t access the network interface. Could you try to ping the switch ?
Moreover normally the GS908E LED turn it amber when it detects some issues on the network, so could you also try with another cable to make sure that´s not a physical issue.
Xavier Lleixa
NETGEAR CBU PLM
Nordman49
Nov 16, 2017Aspirant
