Seb06
Sep 23, 2017Aspirant
GSM5212P SNMP OID for reading Ouput Voltage and current and pethPsePortAdminEnable.X command
Hello to the community,
I try to read output POE voltage and current from a GSM5212P and a also need to switch on and off a port with pethPsePortAdminEnable.X via SNMP.
I find only a limited set of value.
Is a switch limitation or maybe i do something wrong
Switch have firmware : 10.0.2.26
snmpwalk -v 2c -c private 192.168.10.253 powerEthernetMIB :
POWER-ETHERNET-MIB::pethPsePortPowerClassifications.1.3 = INTEGER: class0(1) POWER-ETHERNET-MIB::pethPsePortPowerClassifications.1.4 = INTEGER: class3(4) POWER-ETHERNET-MIB::pethPsePortPowerClassifications.1.5 = INTEGER: class0(1) POWER-ETHERNET-MIB::pethPsePortPowerClassifications.1.6 = INTEGER: class1(2) POWER-ETHERNET-MIB::pethMainPsePower.1 = Gauge32: 120000 Watts POWER-ETHERNET-MIB::pethMainPseOperStatus.1 = INTEGER: on(1) POWER-ETHERNET-MIB::pethMainPseConsumptionPower.1 = Gauge32: 15900 Watts POWER-ETHERNET-MIB::pethMainPseUsageThreshold.1 = INTEGER: 90 % POWER-ETHERNET-MIB::pethNotificationControlEnable.1 = INTEGER: true(1)
and snmpwalk -v 2c -c private 192.168.10.253 fastPathpowerEthernetMIB
NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.1 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.2 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.3 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.4 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.5 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.6 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.7 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.8 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.9 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.10 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.11 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPortReset.1.12 = INTEGER: none(0) NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.1 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.2 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.3 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.4 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.5 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.6 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.7 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.8 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.9 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.10 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.11 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMin.1.12 = Gauge32: 3000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.1 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.2 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.3 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.4 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.5 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.6 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.7 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.8 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.9 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.10 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.11 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethPowerLimitMax.1.12 = Gauge32: 32000 Milliwatts NETGEAR-POWER-ETHERNET-MIB::agentPethMainPseLegacy.1 = INTEGER: true(1)
