lutz
Jun 16, 2011Aspirant
GSM7212 corrupt flash (how to recover)
I become the following problem on _3_ different GSM7212 switches shortly after another: The switches are running long time without any problem. When saving the config with 'save' the saving seems ...
jmizoguchi
Jun 19, 2011Virtuoso
If you can not save, it is possible that there is some issues on NVRAM .
If you purchase the unit after 2007 March, unit has limited lifetime Warranty.
Call support or use my.Netgear.com to find solutions and/or process the RMA
You could try tftp to reflash if that could help as most these switches uses tftp to flash as you probably know it
