Fusion98
May 18, 2017Aspirant
GSM7224P VLAN Routing and DHCP issues
Hi My pc O/S - WIndows 10 Pro, Firmaware of switch - 10.0.1.21, live office envionment. This switch does vlan routing for our 4 vlans. I have attempted to move the vlan routing to a different swit...
- Jul 11, 2017
Hi
Finally figured out what it was. The firewall has a DOS settings for both INTERNAL and external, god knows why internal. Anyhow there is a setting for the speed of your network and one for the speed of your internet. We upgraded our network and internet so the draytek firewall was doing its nut thinking we were under attack and stopped all traffic. Problem is now resolved, many thanks
Retired_Member
May 20, 2017Hi Fusion98,
Welcome to Netgear Community.
From msg.txt, APR replied are invalid, so we guess, there must have large of ARP request/reply, which cause the network congested. there might a kind of ARP attack. can you help enable dymanic ARP inspection? refer page P240 of Admin Manual
Also would you like to answer below couple of questions?
1> any configuration or topoloy change before/after network migration? if yes, what're they?
2> Which device owning IP 192.168.0.1 and MAC 00:50:7f:e7:ce:68?
