Fusion98
May 18, 2017Aspirant
GSM7224P VLAN Routing and DHCP issues
Hi My pc O/S - WIndows 10 Pro, Firmaware of switch - 10.0.1.21, live office envionment. This switch does vlan routing for our 4 vlans. I have attempted to move the vlan routing to a different swit...
- Jul 11, 2017
Hi
Finally figured out what it was. The firewall has a DOS settings for both INTERNAL and external, god knows why internal. Anyhow there is a setting for the speed of your network and one for the speed of your internet. We upgraded our network and internet so the draytek firewall was doing its nut thinking we were under attack and stopped all traffic. Problem is now resolved, many thanks
Fusion98
Jun 02, 2017Aspirant
the ip address of 192.168.0.1 with the mac address you supplied is our main firewall.
I think the issues are hidden as all of the switches in the network use 192,168.0.1 as the gateway, it then (the firewall) has static routes in place to redirect traffic if needed to the netgear switch if accessing a seperate vlan is required.
From the netgears point of view all traffic comes from the firewall.
Fusion98
Jul 11, 2017Aspirant
Hi
