MoneyChanger
Aug 25, 2016Aspirant
GSM7224V2 - ProSafe 24G - Rate Limit by port. Can it be done on this Switch?
Hey, I have a GSM7224V2 with the latest Firmware (8.0.1.36). I am trying to Rate Limit a specific port. I have seen pictures of other NetGear switches with "Rate Limit" feature under the QoS Tab ...
- Aug 30, 2016
DaneA,
Yes your posted guide was helpful. Here is what I have discovered.
The GSM7224V2 WILL limit throughput via the CoS Interface Configuration page found under the QoS Tab and then under Advanced. Egress only from what I can tell.
The setting must be 0-100 (0 being no limit) and 1-100 being a percentage of the interface connection speed.
So for example: On a 100MB link a setting of 2 would set the limit to around 2Mbps.
Example 2: On a 1Gig connection a setting of 2 would set the limit to around 20Mbps.Note: The Traffic Shapping on this switch seems to only support changing the Egress traffic throughput. So on a typical internet speed test, the Download speed to my PC is what is affected while the upload speed is NOT affected.
Thanks for everyones input. I got it working.
- MoneyChanger
MoneyChanger
Aug 26, 2016Aspirant
Thanks for pointing me in the right direction.
For testing I am doing speed tests to the internet to see if my settings are making any change. So far I am not successfully limited traffic on a specific port. Port 0/6 for example I have set to (5) and also (99) and neither of these settings changes the speed test results.
I would like to set the maximum throughput of the interface to say 2Mbps.
Any idea what I am doing wrong?
- JohnRoAug 26, 2016NETGEAR Employee Retired
Hi MoneyChanger,
My advice is to contact our Support Team for your settings to be looked at.
Thanks,
- DaneAAug 30, 2016NETGEAR Employee Retired
Hi MoneyChanger,
Let me share this link below and it might help as reference guide. For further assistance, you may open an online case with NETGEAR Support at anytime.
Rate Limiting / Traffic Shaping
DaneA
NETGEAR Community Team
- MoneyChangerAug 30, 2016Aspirant
DaneA,
- MoneyChanger
Hi MoneyChanger,
I'm glad to know that you got it working. :) I appreciate that you have shared what you have discovered as this will help other community members.
Feel free to post your future concerns here in the community.
Cheers,
DaneA
