Ralf_P
Sep 26, 2023Initiate
GSM7224v2 and SFP module from 10Gtek
Dear forum. I have got two GSM7224v2 switches. Both switches have been reset (via CLI on serial port) and flashed with the latest firmware (8.0.1.36). The switches are running very well with so...
schumaku
Sep 26, 2023Guru - Experienced User
Especially on these older switches, strictly stick with the Netgear modules supported (not just the model flashed) to avoid interoperability issues.
– AGM731F 1000BASE-SX SFP GBIC
– AGM732F 1000BASE-LX SFP GBIC
– AGM733 1000BASE-ZX SFP GBIC
– 100FX SFP LC transceiver
You might have some luck by finding Broadcom-based GBIC modules.
Ralf_P
Oct 03, 2023Initiate
Thank you for your replay. I bought another pair of identical switches (HP ProCurve) and did some testing. The problem was a faulty LC/LC patch cable. Using the new cable a connection using two 10GTek -Modules and one ProCurve and one GSM7224v2 the LEDs on both switches turned immediately green. Best regards.
