adem0x
Nov 12, 2011Aspirant
gsm7248v1 unable to reset
I followed the instructions here: http://support.netgear.com/app/answers/detail/a_id/9665 I even held the reset key down for 30 secs after re-plugging the switch. I have tried admin/password or ...
jmizoguchi
Nov 12, 2011Virtuoso
Other than using the serial port (which I no more have a computer with RS-232, and USB-RS232 adapters don't work properly), is there any other way?
have you heard of USB to serial? on the market for very long time and still commonly available... I use quite often with work... cisco .netgear , juniper...
http://www.cablestogo.com/product.asp?cat_id=1529&sku=26886
Plus... nulll cables. if you still have that came with switch..
this is not same model but here some you would expect to do in console
http://techtips-tom.blogspot.com/2010_11_01_archive.html
you should follow up on GSM manual but you need to console access .. that is quite must for most switched to repair the issues ..
