Sippy
May 22, 2018Aspirant
GSM7312 - Can I regain access? It looks like the management port is disabled, don't know IP
I just inherited a GSM7312 L3 managed switch. If I connect the VT100 terminal and start the switch it says
Hit any key to stop autoboot: 0
then all it shows is a cursor
How can I gain ac...
JohnC_V
May 23, 2018NETGEAR Employee Retired
Hi Sippy,
Welcome to our community! :)
Please make sure that you will reach the console of the switch. Please refer to this manual on page 3-1.
- SippyMay 23, 2018Aspirant
When the switch powers up it stops at the point where it says
Press any key to stop boot
It never gets past this point, which leads me to believe there is no O/S
Either that or the management port is disabled in favor of browser management if that is possible.
I am viewing this from the console port connected to my PC using PuTTy VT100 terminal emulation.
- JohnC_VMay 24, 2018NETGEAR Employee Retired
Have you tried to press "q" button while booting? Once you are in the boot menu, you may recover it using the backup image.
- SippyMay 30, 2018Aspirant
I purchased a new cable, and things went well after that! Doh!
