Felrjn
Jul 12, 2016Aspirant
GSM7328S - Briked terminal not working
I'm trying to make recovery of the firmware through the serial port but I can not update. The swich does not respond, does not connect to the network and not the led the doors. the reset button works...
Felrjn
Jul 13, 2016Aspirant
I did 30-30-30 procedure and did not work, now the terminal after this attempt shows these strange characters that are in print. And now I can try?
Thank you.
JohnRo
Jul 15, 2016NETGEAR Employee Retired
Hi Felrjn,
It appears to me that the flash might be broken. I suggest contacting our Support Team, it might be time for replacement.
Let us know what happens.
Thanks,
- FelrjnJul 20, 2016Aspirant
I do not have the switch documents and do not know when it was purchased. His serial number was already registered before. So in this case what would be the way to contact support?
Thanks!
