micdousmi
Jul 15, 2024Aspirant
GSS116E Power Failure
Woke up this morning and the power was out on my GSS116E. It was working fine last night when I went to bed. I unplugged it and plugged it back in and the power light does not come on and the light...
Jul 15, 2024Guru - Experienced User
Tried a factory reset with all LAN cables disconnected from the switch?
Power cycled OFF for 1 minute with out all LAN cables connected to the switch?
micdousmi
Yes, tried to factory reset with all cabled disconnected.
Also, powered off, tried various outlets and event tested the power adapter with a power meter and its draws power.
- FURRYe38Jul 15, 2024Guru - Experienced User
Ok. Please make contact with the forum moderator.
Good Luck.
- schumakuJul 15, 2024Guru - Experienced User
Leaving alone this is a Plus switch, not a Managed switch (I'll request a mod to move this thread accordingly to the appropriate section). The formal way goes over https://my.netgear.com/ -> [Request Hardware Support]
The same applies to the Limited lifetime* warranty and lifetime support chat - the same channel should be used. -> [Get Support]
