bremke
Nov 06, 2018Aspirant
Having trouble changing network management IP and subnet mask on GSM7224v2 switch
I am having trouble changing the network management IP and subnet mask on a Netgear GSM7224v2 switch.
When I use the network parms command the error I get says, "IP Address/Netmask entered conf...
bremke
Nov 12, 2018Aspirant
Thank you, DaneA. I will give that a try.
bremke
In privileged EXEC mode the command "network protocol none" results in the IP address, subnet mask, default gateway, and Configured IPv4 protocol being reset as expected.
(GSM7224V2) #show network
Interface Status............................... Always Up
IP Address..................................... 0.0.0.0
Subnet Mask.................................... 0.0.0.0
Default Gateway................................ 0.0.0.0
IPv6 Administrative Mode....................... Enabled
IPv6 Prefix is ................................ FE80::E291:F5FF:FEA8:B370/64
Burned In MAC Address.......................... E0:91:F5:A8:B3:70
Locally Administered MAC address............... 00:00:00:00:00:00
MAC Address Type............................... Burned In
Configured IPv4 Protocol....................... None
Configured IPv6 Protocol....................... None
IPv6 AutoConfig Mode........................... Disabled
Management VLAN ID............................. 2
But the "network parms" command doesn't work. I get a message back saying "IP Address/Netmask entered conflicts with the configured IP Address/Netmask of a router interface.
