pchannan
Oct 04, 2013Aspirant
Help - half of network is on wrong IP address
I have a FVS336Gv2 router into a GS724TPS switch and then a couple non-managed 8 port switches (GS108 x2 and a roswell) and two apple extreme wifi routers in bridge mode acting as APs (one directly c...
fordem
Oct 08, 2013Mentor
What version firmware are you running - 3.xx with a yellow background - it's a little different to the older versions.
Create the LAG as step one and then go to membership there should be a yellow bar with a purple arrow pointing to the right - click the yellow bar - it should drop down and allow you to select the ports.
