Logico68
Oct 25, 2021Aspirant
Help with bricked GSM7328Sv1 Switch
I have troubles with an GSM7328Sv1 switch. I have tried to upgrade it to version 8.0.3.49 via TFTP from a version 6.2.0.14 firmware. The upgrade fails and now my switch is bricked. The only thin...
Logico68
Oct 26, 2021Aspirant
quick update:
seems that the "uncompressing" freeze is due to a wrong baud rate on the terminal.
After flashing the 6.2.0.6 firmware and booting in operational mode, the switch reboot itself and set the COM port back to 9600 baud rate.
If in TeraTerm I change the Baud rate back to 9600, I am able to use the console again and the switch is up and running with 6.2.0.6 firmware.
Now, if I try to update the firmware to whatever version (I tried original 6.2.0.14 and the latest 8.0.3.49) it freezes on "Bootcode version upgraded... updating the Bootcode on all the units."
It seems to have problems flashing the new boot code.
Now the only option I have is to restart the switch by plugging off the power cable and re-flash the 6.2.0.6 opr.
In this moment, the only firmware that is usable on my switch is 6.2.0.6 that is not reccomanded to use in production.
Someone has a newer firmware version in opr format, so I can try to flash it through XMODEM?
- neilkeyterDec 06, 2021Initiate
Hello,
I have managed to update my netgear gsm7328 and 528s
I send the update file via ftp.
after all then i did a save of the config.
went to my console window and kept on rebooting.
selected 2 for the start boot menu options and then selected option 11 Restore configuration to factory defaults (delete config files) to delete the boot
when i got the boot option after few minutes i pressed 1 and the new firmware was loaded
hope this will help
below is what i did
NetGear Boot code......
Version 01.00.33 02-03-2011CPU Card ID: 0x508541
Select an option. If no selection in 3 seconds then
operational code will start.1 - Start operational code.
2 - Start Boot Menu.
Select (1, 2):2
Boot MenuOptions available
2 - Change baud rate
3 - Retrieve event log using XMODEM
4 - Load new operational code using XMODEM
5 - Load new operational code using USB
6 - Display operational code vital product data
7 - File system directory listing
8 - Update boot code
9 - Delete backup image
10 - Reset the system
11 - Restore configuration to factory defaults (delete config files)
12 - Activate Backup Image
13 - Password Recovery Procedure
14 - Upload a file through XMODEM
15 - Download a file through XMODEM
[Boot Menu] 11Are you SURE you want to delete the configuration? (y/n):y
[Boot Menu]
[Boot Menu] 1
Operational Code Date: Fri Sep 5 22:46:53 2014
Uncompressing.....
Adding 0 symbols for standalone.
File: cardmgr_cnfgr.c, Line: 354, Error 1446002689 (0x56304001)
Instantiating /download as rawFs, device = 0x20001
Formatting /download for DOSFS
Formatting...OK.
Instantiating RamCP: as rawFs, device = 0x30001
Formatting RamCP: for DOSFS
Formatting...OK.(Unit 1)>
Applying configuration, please wait ...
Applying Global configuration, please wait ...
Applying Interface configuration, please wait ...
User:
Hi
I need to add this i upgraded my firmware from version 6 to version 8 (Latest)
