Logico68
Oct 25, 2021Aspirant
Help with bricked GSM7328Sv1 Switch
I have troubles with an GSM7328Sv1 switch. I have tried to upgrade it to version 8.0.3.49 via TFTP from a version 6.2.0.14 firmware. The upgrade fails and now my switch is bricked. The only thin...
neilkeyter
Dec 06, 2021Initiate
Hello,
I have managed to update my netgear gsm7328 and 528s
I send the update file via ftp.
after all then i did a save of the config.
went to my console window and kept on rebooting.
selected 2 for the start boot menu options and then selected option 11 Restore configuration to factory defaults (delete config files) to delete the boot
when i got the boot option after few minutes i pressed 1 and the new firmware was loaded
hope this will help
below is what i did
NetGear Boot code......
Version 01.00.33 02-03-2011
CPU Card ID: 0x508541
Select an option. If no selection in 3 seconds then
operational code will start.
1 - Start operational code.
2 - Start Boot Menu.
Select (1, 2):2
Boot Menu
Options available
2 - Change baud rate
3 - Retrieve event log using XMODEM
4 - Load new operational code using XMODEM
5 - Load new operational code using USB
6 - Display operational code vital product data
7 - File system directory listing
8 - Update boot code
9 - Delete backup image
10 - Reset the system
11 - Restore configuration to factory defaults (delete config files)
12 - Activate Backup Image
13 - Password Recovery Procedure
14 - Upload a file through XMODEM
15 - Download a file through XMODEM
[Boot Menu] 11
Are you SURE you want to delete the configuration? (y/n):y
[Boot Menu]
[Boot Menu] 1
Operational Code Date: Fri Sep 5 22:46:53 2014
Uncompressing.....
Adding 0 symbols for standalone.
File: cardmgr_cnfgr.c, Line: 354, Error 1446002689 (0x56304001)
Instantiating /download as rawFs, device = 0x20001
Formatting /download for DOSFS
Formatting...OK.
Instantiating RamCP: as rawFs, device = 0x30001
Formatting RamCP: for DOSFS
Formatting...OK.
(Unit 1)>
Applying configuration, please wait ...
Applying Global configuration, please wait ...
Applying Interface configuration, please wait ...
User:
neilkeyter
Hi
I need to add this i upgraded my firmware from version 6 to version 8 (Latest)
