Budgie2
Oct 17, 2014Aspirant
Help with discriminating wifi AP traffic please
Hi, I am seeking some general direction in the best way to discriminate and segregate wireless AP traffic using a managed switch. I can set up several secure SSIDs on the AP and the AP can be se...
fordem
Oct 22, 2014Mentor
Based on my interpretation of your earlier response (#6) no changes to the existing routing arrangements need to be made.
As I understand it - your firebox supports multiple LAN segments, each with it's own range of network addresses - what I'm doing is using the access points to support multiple SSIDs, each on it's own VLAN and then using the M4100 to connect the VLANs to those network segments.
When you find a convenient time - maybe on the weekend - just plug it in and see if it works.
