Budgie2
Oct 17, 2014Aspirant
Help with discriminating wifi AP traffic please
Hi, I am seeking some general direction in the best way to discriminate and segregate wireless AP traffic using a managed switch. I can set up several secure SSIDs on the AP and the AP can be se...
Budgie2
Oct 22, 2014Aspirant
Hi Fordem,
Thanks again. I will give it a try tonight or in the morning. I am not only hindered by needing to keep guests on line but also I am a power injector short so things may be more complicated. Will keep it simple for the trials. Where my understanding falls down is with the internal routing in the switch. Your first reply included the advice:-
It was this I was expecting to do next but appears no longer necessary. Will get back to you after trial. Best wishes, Budgie
The next step will be to configure interVLAN routing on the switch and then set your access lists to prevent the guest VLAN from accessing the office VLAN.
