Budgie2
Oct 17, 2014Aspirant
Help with discriminating wifi AP traffic please
Hi, I am seeking some general direction in the best way to discriminate and segregate wireless AP traffic using a managed switch. I can set up several secure SSIDs on the AP and the AP can be se...
fordem
Oct 22, 2014Mentor
That approach had to be revised because of the configuration of the firewall you are using - as far as I can tell the firebox has multiple internal interfaces and you are already "separating" the office & guest networks there, allowing the switch configuration to be significantly simpler.
