Budgie2
Oct 17, 2014Aspirant
Help with discriminating wifi AP traffic please
Hi, I am seeking some general direction in the best way to discriminate and segregate wireless AP traffic using a managed switch. I can set up several secure SSIDs on the AP and the AP can be se...
fordem
Oct 25, 2014Mentor
A factory default M4100 should be accessible at an address in the 169.254 network (I don't remember what it is, but it's documented) - you will need to configure the computer being used for access at a 169.254 address and also to change this address when you set a new address on the M4100 (assuming you change the network portion of the address).
Also - unlike most Netgear products you need to save any configuration changes as a separate step or they will be lost if the unit is powered off.
