phoenixrising20
Dec 07, 2016Aspirant
Help with Smart Switch Model selection
I just had fiber service installed to my facility and my ISP provided me with 5 static WAN IP addresses. Prior to this I had five cable modems and each modem was connected to a router which provide ...
- Dec 24, 2016
Hi Laurent
Just wanted to close with my experiences, the sales support you recommend was excellent. Based on those discussions I purchased the switch and router you recommended.
As I was installing I had a few configuration issues (issues based on my understanding of the hardware), the Netgear switch came with free 90 day support, which I called to discuss my issues.
The Support engineer was very helpful and cleared up my issues, once again excellent support. All in all I was able to get my network up and running within a day, and per my requirements with the support systems Netgear has in place. Very impressive.
Thank you.
Larry
LaurentMa
Dec 08, 2016NETGEAR Expert
Welcome to the Community!
I don't think you can easily replace a typical Router with any Smart or Managed switch. Reason is that you still need Firewalling and NAT services for your clients (devices). While Smart or Managed switches can handle Static Routing quite easily with Routing IP Interfaces on each of their VLANs, they still need NAT on the gateway for the static routes back.
Put it this way: without a Router, and with the five WAN Fiber connections going straight to a Smart or Managed switch solution, your devices will be able to send packets to the internet, but they will never receive packets in return because of no NAT and no route back to them on WAN side.
I hope it makes sense, please let me know if you need more explanations. In your case, you may want to consider one gateway (router) left on your network connecting to your new WAN fiber service and correctly set up for your five static WAN IP addresses. A Smart Managed switch such as GS724Tv4 could handle VLANs and static routing for your devices, with VLANs for each group of devices and each static WAN IP address. While egress static routes will be set up on your Smart Managed switch, you will then need to set ingress static routes (back) on your router.
Maybe these two posts could further help you:
phoenixrising20
Dec 08, 2016Aspirant
Hi,
Thank you for the information.
I guess I have to understand further on how to configure the Router for the Five Static WAN IP addresses. Do have any suggestion on which Netgear Router would work for this application?
Also would the switch provide the DHCP address for the individual VLANs?
Thanks again
