phoenixrising20
Dec 08, 2016Aspirant
Help with Smart Switch Model selection
I just had fiber service installed to my facility and my ISP provided me with 5 static WAN IP addresses. Prior to this I had five cable modems and each modem was connected to a router which provide ...
- Dec 24, 2016
Hi Laurent
Just wanted to close with my experiences, the sales support you recommend was excellent. Based on those discussions I purchased the switch and router you recommended.
As I was installing I had a few configuration issues (issues based on my understanding of the hardware), the Netgear switch came with free 90 day support, which I called to discuss my issues.
The Support engineer was very helpful and cleared up my issues, once again excellent support. All in all I was able to get my network up and running within a day, and per my requirements with the support systems Netgear has in place. Very impressive.
Thank you.
Larry
LaurentMa
Dec 08, 2016NETGEAR Expert
Any NETGEAR Prosafe Firewall/Router would manage five static WAN IP addresses in your network: I would advise the SRX5308 here.
In order to have the switch providing DHCP addresses to your devices for the individual VLANs, we need to have DHCP server in the switch. This is one of the key differences between NETGEAR Smart Managed switches and NETGEAR Fully Managed switches. DHCP Server will only be in NETGEAR Fully Managed switches, with DHCP Pools for each individual VLANs. Maybe this post will be useful for you in terms of DHCP Server: DHCP how-to.
For the record, you may also have DHCP services outside of the switch, for instance on one SBS server or on your router. In that case, DHCP Relay is needed on the switch so that your devices can easily get their IP addresses. Here again, only NETGEAR Fully Managed switches will provide these DHCP Relay (IP Helper) services at Layer 3 for UDP.
I would advise M4100 series for you, if no other requirements than Gigabit ports and static routing: NETGEAR M4100 Fully Managed switches are excellent Intelligent Edge models with great software and very affordable price points, just above Smart Managed switches. A fully functional Web interface (GUI) is available for easy configuration and easy management. M4100-26G (GSM7224v2) would be the one in your case.
For the Firewall/VPN Router configuration, I think you can find good explanations in this SRX5308 Reference Manual on page 33 then page 38 (IP Configuration).
phoenixrising20
Dec 09, 2016Aspirant
Thanks again for the information, you have been very helpful. I have review the two products you mentioned, and I somewhat see how they would work. I have several additional detailed questions, is there soemone I could talk to go over the system.
Thanks
Larry
