GregC123
Dec 09, 2020Initiate
How can I Factory Default a GSM7212F without the password
I do not have the login and password but cannot find how to otherwise reset the switch to factory defaults? There isnt a noticeable factory default pin button on the device, and when I connect a con...
- Dec 09, 2020
Well after many many articles and not finding how I looked at one more which reference pressing Q when it was starting and the menu would come up in the serial interface. It worked! Solved.
GregC123
