Nils-GSR
Mar 12, 2024Aspirant
HOW MANY VLANS ON A FIBER TRUNK OF A M4250: ONLU SEEING DATA NOT AUDIO DANTE AND DATA
I might be missing something but I'm not able to get the Dante Audio signal data down the fiber port sharing with Data; data is fine, just no Dante Signal. Under port configuration it shows only data...
LaurentMa
Mar 12, 2024NETGEAR Expert
Hi Nils-GSR ,
Something misconfigured I'm sure - if the port is Auto-Trunk it means all VLANs are going through - but it also means you are going to another M4250 switch, right?
Please make sure you are running the latest firmware (M4250 FW); also if you have several switches, you can follow our application notes with very detailed how-to's here: AV over IP Technical Guides - NETGEAR
If the problem persists, don't worry, a ProAV Design System Engineer will help you: email us at ProAVDesign@netgear.com
Thank you,
Laurent
Nils-GSR
Mar 26, 2024Aspirant
Left VLAN 1 and passed all of my data traffic there, set up a VLAN for Dante then configured the Dante card, and it worked. Very Cool, thank you.
Up until I tried to add another static data VLAN profile to separate the two data environments (Netgear default and Audio Architect control).
That addition results in a "Add Interface IP error"?
VLAN 1: Static; IP=XXX.XXX.10.XXX DHCP OFF; success
VLAN 20 Static IP=XXX.XXX.20.XXX; DHCP ON; success
VLAN 50 Static IP=XXX.XXX.50.XXX; DHCP OFF; Add Interface IP error
