keithwong
May 03, 2016Aspirant
How to backup and restore configuration for 4 switches (stacked)
Dear All, I would like to figure out how to fullly backup configuration from 4 switches that they have formed stack currently ( 1 GUI manage 4 switches) Does there any procedure i can follow ...
keithwong
May 04, 2016Aspirant
Hi John,
Thanks for your reply.
I have read the link you provided and it is useful.
Question: how could i restore the configuration to these staked switches ?
Do i need to re-form the stack first ? or I can restore it via the GUI "Download" ?
Thank You
JohnRo
May 04, 2016NETGEAR Employee Retired
Hello keithwong,
Yes, you will have to re-form the stack. Please also take note that the configuration file can only be downloaded to the Master Stacking Unit.
Thanks,
