oilolay
Mar 15, 2017Aspirant
How to configure a port for multiple vlan on M4300-8X8F
Hi, I'm new here and new to the vlan field and have a vlan issue need you guys to help. I have an Netgear M4300-8x8F switch and two x86_64 server, the simple diagram display as shown below, ...
DanielZhang
Mar 15, 2017NETGEAR Expert
Hi Oilolay,
Welcomet to NETGEAR community!:smileyhappy:
You should add these VLAN first.
The CLI is recommend method to create VLAN.
You can also name the VLAN just created by CLI from GUI.
Then add VLAN for port of switch by GUI.
This configuration will make VLAN Tag 10,500-515,600-615 on port.
oilolay
Hi Daniel_Z,
Thank you for the reply. I'm still stupid in this ...
May I know why the PVID is 10, not set it as 4?
And according the describtion, it will make multiple vlan on the switch port 1. If I did the same thing for the switch port 2, and the can make both of server to communicate to each other?
