ksb's avatar
ksb
How to disable switch from sending LLDP multicast packets?
The M4300 switch keeps sending LLDP multicast packets every 15seconds even though LLDP has been disabled on all interfaces. Does anyone know how to stop those packets?
Thank you
  • Hi,
    You have to disable the LLDP Transmit on the ports where you don't want LLDP packets to be send out of.
    "System" --> "LLDP" --> "Port Configuration" --> Set "Transmit" to disable on the desired ports. Done.
    Cheers
    • ksb's avatar
      ksb
      Thank you. I have already done that, but the switch still sends LLDP multicast packet every 15s.
      • Hopchen's avatar
        Hopchen
        Prodigy
        Hi,
        I confirmed this with Wireshark. The LLDP messages stop completely if LLDP Transmit is set to Disabled on the port.
        How are you testing this? Are you the latest firmware?
ProSupport for Business
