DSUK73
Apr 21, 2022Aspirant
How to set JGS524Ev2 port to 1000/Full
Is it possible to set a port on my Switch to 1000/Full duplex? The reason being that a connected device is autonegotiating down to 100Mbps despite being capable of running at 1Gbps. I'm hoping that f...
JeraldM
Apr 25, 2022NETGEAR Employee Retired
Welcome to the community!
It's not possible to manually set a port to 1000Mbps/Full. If the speed is set to Auto then the linked speed should show "1000M Full" provided that the connected device is capable of such.
In your case, have you tried using a different Ethernet cable and/or a workstation? Also, is that the only device that establishes a 100Mbps connection?
JeraldM
NETGEAR Community Team
schumaku
Apr 25, 2022Guru - Experienced User
Here again, link negotiation is mandatory on copper Ethernet for speeds of 1000M and up. There is no "I want".
Problems with speed negotiation failures are bad adapters, poor drivers, bad wiring.
