ttanemori
Apr 28, 2016Aspirant
How to set up Mirroring
Hi, I want to configure port mirroring. Because it is a production swtich, I want to make sure if these steps are correct. Could you help me, please?
M4100-50G-POE+
Source port 1 and 2
Destination port 3
1. In the admin console, I go to Monitoring and Mirroring.
2. Under Mirroring Global Configuration, I choose 0/3 as Destination Interface. Change the Session Mode to Enable.
3. Under Status table, check on 0/1 and 0/2, and change Direction to "Tx and Rx"
4. Click on Apply.
5. Go to "Maintenance" tab and check box on at "Save Configuration."
Am I understanding correct? Will there be a down time? Is the swtich going to be rebooted?
Any advice is appreciated.
Thank you very much.
Hello ttanermori,
It appears correct to me, click here for instructions (it will look a little different due to its firmware version). Regarding your questions, is it downtime and reboot upon enabling? As far as I know it should not.
Let us know if you have more questions.
Thanks,
- JohnRoNETGEAR Employee Retired
Hello ttanermori,
Thanks,
- ttanemoriAspirant
Thank you very much! I will read and keep the document.
Best regards,- JohnRoNETGEAR Employee Retired
Hello ttanemori,
You are welcome! If ever one of the posts on this thread helped you, please mark it as "Accept as Solution", this will help other members of the community to maximize their search options when looking up a specific issue.
Thanks,
