tonynsx's avatar
tonynsx
Luminary
Dec 09, 2020
How to setup LAG between 2 Netgear switches?
I'm trying to setup LAG between 2 Netgear switches, but its not working.  The switches I'm using are S3300-52X-PoE+ ProSAFE 48-Port Gigabit Stackable Smart Switch with PoE+ and 4 10G uplinks and XS72...
  • schumaku's avatar
    schumaku
    Dec 09, 2020
    Here again, the same setings must be used on both ends. And for the obvious (?) reasons, only one VLAN can be run untagged and with the same PVID configured.
ProSupport for Business
