tonynsx
Dec 09, 2020Luminary
How to setup LAG between 2 Netgear switches?
I'm trying to setup LAG between 2 Netgear switches, but its not working. The switches I'm using are S3300-52X-PoE+ ProSAFE 48-Port Gigabit Stackable Smart Switch with PoE+ and 4 10G uplinks and XS72...
- Dec 09, 2020
Here again, the same setings must be used on both ends. And for the obvious (?) reasons, only one VLAN can be run untagged and with the same PVID configured.
tonynsx
I suppose so, but in the documentation it says I can use U or T, besides the cat 5 trunk was using U
schumaku
Dec 09, 2020Guru - Experienced User
