rgubele
Apr 28, 2020Aspirant
IGMP Snooping filtering OSPF except on VLAN 1
Hello, I am experiencing an issue where OSPF routers connectted m4300-series switches running IGMP Snooping are unable to form an adjacency. The m4300-series switches seem to be filtering OSPF mu...
- Apr 30, 2020
In 12.0.11.x we introduced a new command 'set igmp-plus" which is needed for all reseved multicast addresses to work.
I beliveve following configuration should fix your issue
vlan database
vlan 20
set igmp-plus 20
LaurentMa
Apr 28, 2020NETGEAR Expert
Thank you, schumaku
Hi rgubele
I am sorry for your issue, let's go and fix it. Kindy export the Tech-Support file out, you can simply go the web GUI, Maintenance \ Export \ HTTP File Export \ and select Tech Support at the end of the drop down menu list.
You can use the private message here to let me know where I can get that file, and we'll be able to assess where is the problem.
Thank you,
