Gerenuk
Nov 22, 2015Aspirant
IGMPv3 support for m4100 series
Hallo, I have a M4100 (FW: 10.0.2.13) which I specifically purchased because the specs indicate support for IGMPv3 snooping and querier. However, when I try to configure igmp I only have the option...
- Nov 30, 2015
Hi Gerenuk,
That's great! Hopefully you will be able to accomplish the setup you wanted.
Have a great day!
Thanks,
JohnRo
Nov 23, 2015NETGEAR Employee Retired
Hello Gerenuk,
Welcome to the community!
Try using CLI instead, check page 154 of the CLI manual. Can you also post as screenshot of where you are changing it using the WEB GUI?
Looking forward to your response.
Thanks,
Gerenuk
Nov 25, 2015Aspirant
Hallo JohnRo,
thank you for your reply. I also logged a call with Netgear support and got the explanation from them.
The IGMP snooping function supports v1,v2 and v3. The IGMP querier only supports v1 and v2. This is the reason I can only select v1 or v2 when configuring the querier. I do not really need the quereir to run v3, so this explanation helped me solve the issue I was having.
Gerenuk
- JohnRoNov 30, 2015NETGEAR Employee Retired
Hi Gerenuk,
Have a great day!
Thanks,
