Meier's avatar
Meier
Follower
May 11, 2016
GS108T IGMPv3 support?
I have a question about the NETGEAR GS108Tv2. For me it’s not clear if the GS108Tv2 supports IGMPv3. On the Features Page http://www.netgear.com/business/products/switches/smart/GS108Tv2.aspx#tab-features its written « IGMP Snooping, v1, v2 und v3» and on the Datasheet http://www.downloads.netgear.com/files/GDC/datasheet/en/GS108Tv2.pdf «IGMP snooping v1/v2». Does the GS108T now support IGMPv3 or not?
  • I have a GS108T on my desk running on 5.4.2.22 (latest) firmware - looks like IGMPv3 is not avalible. Only v1 and v2.
    • JohnRo's avatar
      JohnRo
      NETGEAR Employee Retired
      Hello Meier,
      Welcome to the community!
      I agree with mgmtmt's post, I don't see IGMPv3 available for the Smart Managed versions. I saw IGMPv3 available on M4100 series switches.
      Thanks,
    • JohnRo's avatar
      JohnRo
      Hello Meier,
      We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
      If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
      Thanks,
ProSupport for Business
