Gerenuk
Nov 22, 2015Aspirant
IGMPv3 support for m4100 series
Hallo, I have a M4100 (FW: 10.0.2.13) which I specifically purchased because the specs indicate support for IGMPv3 snooping and querier. However, when I try to configure igmp I only have the option...
- Nov 30, 2015
Hi Gerenuk,
That's great! Hopefully you will be able to accomplish the setup you wanted.
Have a great day!
Thanks,
Gerenuk
Nov 25, 2015Aspirant
Hallo JohnRo,
thank you for your reply. I also logged a call with Netgear support and got the explanation from them.
The IGMP snooping function supports v1,v2 and v3. The IGMP querier only supports v1 and v2. This is the reason I can only select v1 or v2 when configuring the querier. I do not really need the quereir to run v3, so this explanation helped me solve the issue I was having.
Gerenuk
JohnRo
Nov 30, 2015NETGEAR Employee Retired
Hi Gerenuk,
Have a great day!
Thanks,
