PoliIT
Jan 21, 2019Follower
Inactive ports in M4300-52G switch even if physically connected
Hi,
I have two keyboards for access control connected with two integrated network cards to my LAN, with a static IP address set.
These keyboards are in use since years, without problems. Now I ch...
JohnC_V
Jan 29, 2019NETGEAR Employee Retired
Hi PoliIT,
Welcome to our community! :)
It seems that you were trying to use this keyboards for accessing the console of the switch. It would not work on these type of switches as it uses USB mini for the CLI.
Here is the installation guide.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
