swanD
Mar 14, 2019Follower
interface rack mount kit M4300-24X
hi all,
for an application I want to make/design custom made brackets for the managed switch M4300-24X. I want to use the 4 interfaces on the side of the switch on the front and on the back sid...
LaurentMa
Mar 15, 2019NETGEAR Expert
Yes NETGEAR can help and share mechanical external drawings (CAD 3D and 2D in STEP) under non-disclosure mutual agreement.
Please come to me using Private Message and provide our complete details with your email. I will follow up asap with you, go and execute our mutual NDA and provide the drawings to you, you'll have everything you need I hope for your mounting kit application.
NB: As soon as the switch case gets opened or modified, NETGEAR warranty is voided. I understand here you will only work outside of the switch, which seems OK.
