LaurentMa
Apr 10, 2018NETGEAR Expert
Introducing: 5-, 7-, 10-, 15- and 20-meter Direct Attach SFP+ cables
Plug and play simplicity shouldn’t break the bank: Get the new Plug and Play DAC Cables at a lower price than fiber transceivers.
Introducing new Active and Optical DAC versions of 5-, 7-, 10...
LaurentMa
Apr 13, 2018NETGEAR Expert
P-Dog This should work nicely between the Nighthawk X10 WiFi router SFP+ port, and the Insight Managed Smart Cloud switch GS728X SFP+ port. You can select the 10-meter version for 25 feet distance, or 15-meter, or 20-meter as you see fit.
Such DAC cable isn't made of real SFP+ fiber transceivers: instead, their connectors are SFP+ compatible and recognized as DAC by the endpoints.
I hope this helps!
P-Dog
Apr 13, 2018Tutor
Thank you LaurentMa, not sure if you would be able to help me with this. But do you know which out of these two 10G Transceiver are compatible with the X10 router and the GC728x switch?
Is it the AXM761-10000s or AXM763-10000s
