LaurentMa
Apr 10, 2018NETGEAR Expert
Introducing: 5-, 7-, 10-, 15- and 20-meter Direct Attach SFP+ cables
Plug and play simplicity shouldn’t break the bank: Get the new Plug and Play DAC Cables at a lower price than fiber transceivers.
Introducing new Active and Optical DAC versions of 5-, 7-, 10...
P-Dog
Apr 13, 2018Tutor
Thank you LaurentMa, not sure if you would be able to help me with this. But do you know which out of these two 10G Transceiver are compatible with the X10 router and the GC728x switch?
Is it the AXM761-10000s or AXM763-10000s
schumaku
Apr 14, 2018Guru - Experienced User
The difference is not in the compatibility,it's about the wavelength - you can deploy all these to the X10 and the GC728X. The AXM761 is optimised for multimode 50/125µm OM3 (up to 300 meters) or OM4 (up to 550 meters) fiber [Laser], while the AXM763 is optimised for multimode 62.5/125µm OM1/OM2 (up to 220 meters) [850/1300nm]. Both can drive the other fiber standard, the reach will be limited.
