robfantini
Jul 12, 2017Aspirant
IP address is incorrect in logs.
we have a M4100-50G-POE+ lagged to a GSM7352Sv2. logs for the M4100 on screen and at rsyslog server show the address for the GSM7352Sv2. Note there is also a GSM7224V2 lagged to the GSM735...
- Retired_MemberJul 18, 2017
re: "1. Upload config-file from Switch" so just save a 'Text Configuration' . Correct?
no, you need to copy configuration file to laptop.
An example for CLI command:
First, setup one TFTP server on laptop(example IP is 1.1.1.1)
Second, execute command as 'save'
Third, execute command as 'copy nvram:startup-config tftp://1.1.1.1/m4100-config'
re: "Then erase the configure in the switch" . from cli what is the command for that?
execute command as 'clear config'
Then download the configuraiton file via CLI command as below:
copy tftp://1.1.1.1/m4100-config nvram:startup-config
robfantini
Jul 18, 2017Aspirant
quick questions
Also should I remove this : network mgmt_vlan . I added that recently
and to restore I'll download the edited file.
Retired_Member
Jul 18, 2017
- robfantiniJul 18, 2017Aspirant
after clearing config, I was not able to access the tftp server. so I used copy and paste from cli to restore the config.
The switch now logs with the correct IP address so this is close to solved.
I will have to do the above for another switch and would like to have access to tftp server after clear config.
this switch is connected by lag to main switch.
the pvid is 8 on the lag.
and suggestions to the connected to tftp server after clear config?
If it cannot access to TFTP Server.
You can copy the command in config files directly and paste to console port for executing.
OK I have one more switch to try to get logging correct on. Issue is about same as m4100. I'll post another thread as the model is different?
the switch is stack of GSM7352Sv2 which does all our routing.
It's doesn't matter for different type switch, as they are all Managed Switch, and operation is same. You can do same steps to resolve the problem.
the 7352 does not have a 'network parms 169.254.100.100 255.255.0.0 0.0.0.0' line in config.
there are differences so I'll open ip another thread. thank you for the help .
- Oct 24, 2016Retired_Member
